Hi guys,
I'm new to PSoC. Can you help me find a suitable alternative for CY8C5867LTI-LP025/028? We badly need it in production but the present shortage in chips are making this particular part hard to find. Maybe you know an alternative that doesn't deviate much in terms of internal and external (physical) specifications of the chip.
Thanks in advance!
PSoC general
- psoc
jon_f,
Roy Liu provided a Infineon parametric chart of similar PSoC5LP devices.
I'm assuming the desired option is to find a part that is a "drop-in" replacement for your original part. That way you don't have to redesign your PCB.
One important match is the package size and type. The original part is a 68-pin QFN. This should be your first filter in the parametric search.
The PSoC Creator also has a parametric search tool.
By selecting the project and then "Device Selector..."
you get the parametric search tool. Using the "Hide/Show Columns" you can select only the resources needed by your project.
Then you can further filter the results to narrow down the search. For example, if you want to match the Package to 68-QFN
This will significantly narrow your search criteria.
You can further narrow the search but I don't know your project resource needs.
Here is an example filtered list on the 68-QFN.
The technical support platform does not know which chips are not shortage. Maybe you can contact your sales or Infineon marketing.
The other devices of the same product family(PSoC5lp) with CY8C5867LTI-LP025/028 ARM Cortex-M3 core MCU are listed here
And as mentioned in the last post, very limited knowledge about products supplying, but generally, PSoC6 is the most closed product, and supply status should be better than PSoC5lp currently, but both Hardware and Firmware need redesign.
jon_f,
Hello everyone,
Thanks for the wonderful tips. We already found the suitable drop-in alternatives for the LP025/28 (they were even better in specs. Len's tips were especially helpful.
Warm Regards,
Jon
