I just found out that a flash on CY8C27643-24PVXI on the device which I am testing is "W" protected.
1 output port on this controller is damaged ( I suppose I can send logic 1 and 0 to that port and check using Designer software . What is easiest way to check if chip ports are not damaged?
I thought best option is just to get a programmer for $50. buy few new chips . Then to read data off the original chip, desolder from the board old chip, solder new chip and save a program on the new chip.
here is data from the old chip :
Read Finished at 3:57:24 PM |
| 0000: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0010: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0020: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0030: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0040: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0050: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0060: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0070: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0080: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0090: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 00a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 00b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 00c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 00d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 00e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 00f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0100: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0110: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0120: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0130: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0140: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0150: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0160: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0170: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0180: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0190: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 01a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 01b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 01c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 01d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 01e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 01f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0200: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0210: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0220: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0230: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0240: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0250: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0260: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0270: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0280: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0290: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 02a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 02b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 02c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 02d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 02e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 02f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0300: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0310: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0320: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0330: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0340: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0350: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0360: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0370: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0380: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0390: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 03a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 03b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 03c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 03d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 03e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 03f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0400: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0410: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0420: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0430: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0440: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0450: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0460: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0470: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0480: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0490: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 04a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 04b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 04c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 04d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 04e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 04f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0500: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0510: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0520: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0530: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0540: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0550: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0560: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0570: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0580: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0590: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 05a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 05b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 05c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 05d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 05e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 05f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0600: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0610: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0620: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0630: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0640: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0650: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0660: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0670: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0680: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0690: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 06a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 06b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 06c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 06d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 06e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 06f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0700: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0710: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0720: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0730: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0740: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0750: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0760: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0770: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0780: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0790: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 07a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 07b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 07c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 07d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 07e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 07f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0800: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0810: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0820: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0830: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0840: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0850: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0860: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0870: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0880: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0890: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 08a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 08b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 08c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 08d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 08e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 08f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0900: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0910: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0920: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0930: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0940: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0950: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0960: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0970: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0980: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0990: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 09a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 09b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 09c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 09d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 09e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 09f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0a00: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0a10: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0a20: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0a30: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0a40: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0a50: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0a60: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0a70: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0a80: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0a90: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0aa0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0ab0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0ac0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0ad0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0ae0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0af0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0b00: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0b10: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0b20: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0b30: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0b40: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0b50: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0b60: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0b70: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0b80: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0b90: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0ba0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0bb0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0bc0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0bd0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0be0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0bf0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0c00: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0c10: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0c20: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0c30: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0c40: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0c50: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0c60: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0c70: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0c80: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0c90: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0ca0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0cb0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0cc0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0cd0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0ce0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0cf0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0d00: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0d10: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0d20: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0d30: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0d40: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0d50: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0d60: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0d70: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0d80: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0d90: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0da0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0db0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0dc0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0dd0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0de0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0df0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0e00: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0e10: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0e20: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0e30: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0e40: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0e50: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0e60: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0e70: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0e80: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0e90: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0ea0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0eb0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0ec0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0ed0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0ee0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0ef0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0f00: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0f10: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0f20: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0f30: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0f40: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0f50: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0f60: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0f70: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0f80: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0f90: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0fa0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0fb0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0fc0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0fd0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0fe0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 0ff0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1000: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1010: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1020: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1030: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1040: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1050: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1060: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1070: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1080: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1090: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 10a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 10b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 10c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 10d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 10e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 10f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1100: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1110: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1120: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1130: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1140: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1150: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1160: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1170: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1180: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1190: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 11a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 11b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 11c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 11d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 11e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 11f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1200: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1210: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1220: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1230: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1240: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1250: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1260: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1270: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1280: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1290: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 12a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 12b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 12c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 12d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 12e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 12f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1300: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1310: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1320: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1330: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1340: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1350: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1360: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1370: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1380: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1390: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 13a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 13b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 13c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 13d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 13e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 13f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1400: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1410: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1420: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1430: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1440: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1450: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1460: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1470: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1480: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1490: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 14a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 14b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 14c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 14d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 14e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 14f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1500: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1510: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1520: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1530: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1540: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1550: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1560: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1570: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1580: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1590: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 15a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 15b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 15c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 15d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 15e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 15f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1600: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1610: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1620: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1630: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1640: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1650: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1660: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1670: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1680: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1690: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 16a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 16b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 16c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 16d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 16e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 16f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1700: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1710: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1720: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1730: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1740: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1750: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1760: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1770: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1780: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1790: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 17a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 17b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 17c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 17d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 17e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 17f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1800: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1810: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1820: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1830: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1840: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1850: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1860: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1870: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1880: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1890: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 18a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 18b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 18c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 18d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 18e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 18f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1900: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1910: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1920: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1930: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1940: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1950: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1960: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1970: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1980: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1990: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 19a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 19b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 19c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 19d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 19e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 19f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1a00: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1a10: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1a20: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1a30: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1a40: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1a50: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1a60: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1a70: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1a80: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1a90: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1aa0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1ab0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1ac0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1ad0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1ae0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1af0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1b00: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1b10: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1b20: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1b30: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1b40: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1b50: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1b60: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1b70: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1b80: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1b90: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1ba0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1bb0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1bc0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1bd0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1be0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1bf0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1c00: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1c10: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1c20: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1c30: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1c40: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1c50: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1c60: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1c70: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1c80: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1c90: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1ca0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1cb0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1cc0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1cd0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1ce0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1cf0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1d00: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1d10: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1d20: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1d30: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1d40: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1d50: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1d60: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1d70: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1d80: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1d90: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1da0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1db0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1dc0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1dd0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1de0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1df0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1e00: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1e10: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1e20: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1e30: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1e40: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1e50: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1e60: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1e70: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1e80: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1e90: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1ea0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1eb0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1ec0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1ed0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1ee0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1ef0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1f00: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1f10: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1f20: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1f30: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1f40: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1f50: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1f60: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1f70: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1f80: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1f90: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1fa0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1fb0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1fc0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1fd0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1fe0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 1ff0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2000: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2010: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2020: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2030: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2040: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2050: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2060: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2070: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2080: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2090: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 20a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 20b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 20c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 20d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 20e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 20f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2100: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2110: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2120: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2130: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2140: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2150: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2160: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2170: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2180: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2190: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 21a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 21b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 21c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 21d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 21e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 21f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2200: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2210: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2220: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2230: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2240: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2250: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2260: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2270: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2280: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2290: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 22a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 22b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 22c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 22d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 22e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 22f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2300: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2310: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2320: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2330: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2340: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2350: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2360: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2370: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2380: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2390: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 23a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 23b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 23c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 23d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 23e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 23f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2400: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2410: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2420: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2430: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2440: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2450: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2460: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2470: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2480: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2490: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 24a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 24b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 24c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 24d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 24e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 24f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2500: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2510: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2520: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2530: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2540: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2550: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2560: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2570: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2580: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2590: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 25a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 25b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 25c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 25d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 25e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 25f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2600: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2610: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2620: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2630: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2640: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2650: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2660: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2670: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2680: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2690: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 26a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 26b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 26c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 26d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 26e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 26f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2700: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2710: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2720: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2730: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2740: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2750: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2760: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2770: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2780: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2790: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 27a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 27b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 27c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 27d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 27e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 27f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2800: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2810: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2820: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2830: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2840: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2850: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2860: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2870: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2880: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2890: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 28a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 28b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 28c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 28d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 28e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 28f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2900: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2910: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2920: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2930: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2940: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2950: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2960: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2970: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2980: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2990: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 29a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 29b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 29c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 29d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 29e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 29f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2a00: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2a10: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2a20: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2a30: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2a40: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2a50: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2a60: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2a70: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2a80: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2a90: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2aa0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2ab0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2ac0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2ad0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2ae0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2af0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2b00: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2b10: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2b20: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2b30: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2b40: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2b50: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2b60: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2b70: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2b80: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2b90: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2ba0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2bb0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2bc0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2bd0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2be0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2bf0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2c00: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2c10: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2c20: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2c30: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2c40: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2c50: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2c60: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2c70: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2c80: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2c90: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2ca0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2cb0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2cc0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2cd0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2ce0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2cf0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2d00: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2d10: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2d20: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2d30: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2d40: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2d50: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2d60: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2d70: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2d80: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2d90: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2da0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2db0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2dc0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2dd0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2de0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2df0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2e00: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2e10: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2e20: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2e30: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2e40: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2e50: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2e60: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2e70: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2e80: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2e90: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2ea0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2eb0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2ec0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2ed0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2ee0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2ef0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2f00: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2f10: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2f20: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2f30: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2f40: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2f50: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2f60: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2f70: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2f80: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2f90: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2fa0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2fb0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2fc0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2fd0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2fe0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 2ff0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3000: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3010: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3020: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3030: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3040: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3050: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3060: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3070: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3080: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3090: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 30a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 30b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 30c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 30d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 30e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 30f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3100: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3110: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3120: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3130: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3140: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3150: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3160: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3170: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3180: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3190: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 31a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 31b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 31c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 31d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 31e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 31f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3200: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3210: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3220: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3230: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3240: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3250: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3260: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3270: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3280: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3290: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 32a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 32b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 32c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 32d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 32e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 32f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3300: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3310: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3320: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3330: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3340: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3350: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3360: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3370: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3380: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3390: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 33a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 33b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 33c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 33d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 33e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 33f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3400: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3410: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3420: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3430: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3440: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3450: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3460: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3470: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3480: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3490: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 34a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 34b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 34c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 34d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 34e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 34f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3500: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3510: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3520: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3530: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3540: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3550: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3560: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3570: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3580: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3590: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 35a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 35b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 35c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 35d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 35e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 35f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3600: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3610: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3620: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3630: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3640: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3650: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3660: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3670: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3680: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3690: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 36a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 36b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 36c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 36d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 36e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 36f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3700: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3710: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3720: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3730: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3740: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3750: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3760: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3770: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3780: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3790: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 37a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 37b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 37c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 37d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 37e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 37f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3800: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3810: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3820: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3830: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3840: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3850: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3860: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3870: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3880: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3890: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 38a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 38b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 38c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 38d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 38e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 38f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3900: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3910: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3920: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3930: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3940: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3950: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3960: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3970: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3980: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3990: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 39a0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 39b0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 39c0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 39d0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 39e0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 39f0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3a00: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3a10: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3a20: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3a30: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3a40: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3a50: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3a60: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3a70: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3a80: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3a90: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3aa0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3ab0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3ac0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3ad0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3ae0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3af0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3b00: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3b10: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3b20: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3b30: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3b40: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3b50: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3b60: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3b70: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3b80: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3b90: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3ba0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3bb0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3bc0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3bd0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3be0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3bf0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3c00: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3c10: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3c20: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3c30: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3c40: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3c50: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3c60: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3c70: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3c80: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3c90: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3ca0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3cb0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3cc0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3cd0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3ce0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3cf0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3d00: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3d10: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3d20: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3d30: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3d40: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3d50: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3d60: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3d70: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3d80: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3d90: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3da0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3db0: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
| 3dc0: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3dd0: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3de0: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3df0: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3e00: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3e10: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3e20: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3e30: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3e40: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3e50: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3e60: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3e70: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3e80: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3e90: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3ea0: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3eb0: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3ec0: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3ed0: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3ee0: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3ef0: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3f00: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3f10: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3f20: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3f30: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3f40: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3f50: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3f60: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3f70: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3f80: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3f90: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3fa0: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3fb0: 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
| 3fc0: a5 13 01 00 35 01 4c 04 00 fc 7f 7f 7f ff ff ff
| 3fd0: ff ff 00 00 00 1a 00 00 02 ff ff ff 0f f2 00 00
| 3fe0: 00 00 00 00 00 00 00 30 82 00 01 05 05 04 4c 00
| 3ff0: 96 00 00 01 35 00 00 05 05 00 00 01 00 00 00 00
| --- Flash Security Data ---
| 0000: W W W W W W W W W W W W W W W W
| 0400: W W W W W W W W W W W W W W W W
| 0800: W W W W W W W W W W W W W W W W
| 0c00: W W W W W W W W W W W W W W W W
| 1000: W W W W W W W W W W W W W W W W
| 1400: W W W W W W W W W W W W W W W W
| 1800: W W W W W W W W W W W W W W W W
| 1c00: W W W W W W W W W W W W W W W W
| 2000: W W W W W W W W W W W W W W W W
| 2400: W W W W W W W W W W W W W W W W
| 2800: W W W W W W W W W W W W W W W W
| 2c00: W W W W W W W W W W W W W W W W
| 3000: W W W W W W W W W W W W W W W W
| 3400: W W W W W W W W W W W W W W W W
| 3800: W W W W W W W W W W W W W W W W
| 3c00: W W W W W W W U U U U U U U U U
| Reading 16384 bytes of FLASH
Read Requested at 3:57:14 PM |
Successfully Connected to MINIProg1/801B8A463E16 at 3:57:01 PM | MINI Version 1.79
Opening Port at 3:56:59 PM |
Device set to CY8C27643-24*PXI at 3:56:46 PM | 16384 FLASH bytes
What are the chances that if I write this to new chip it will work ?
I suspect it is 0% chance.
I do not want to steal data on the original chip just to copy to new chip, Is there any other option ?
Thanks for help.
here is rest of my post ( orioginal was cut by forum )
...... | 3d90: xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx xx
Thanks for help.
Thanks for help.
here is a picture of the device I am fixing. It would cost me only $60 + soldering time to fix it if data was not protected and now it looks like a new board from manufacturer for $699 + shipping
I guess times " do it yourself " are over . everything is a corporate property and times of troubleshooting electronics are no more.
greetings from Toronto
73
Hi Jacek,
The reading of W Protected blocks through any programmer is not possible. If you see the data that you have read, the data is valid only from 3dc0 from which the blocks are Unprotected (U). The blocks with W Protection are showing xx. So, this wont help you.
To check if ports are damaged, best way is to toggle the pin and check.
If you dont have the hex file or the project, then i dont find any method to proceed.
Keerthi Raj
