Trying to read ADC values, utilizing the debug function. But it seems , that I cannot use the add watch button, to read the value from the variable.
I am using PSoC 5LP CY8C5888LT*LP097.
The Code:
include "project.h"
// CyGlobalIntEnable; /* Enable global interrupts. */
IDAC8_1_Start();
IDAC8_1_SetPolarity(IDAC8_1_SINK);
ADC_DelSig_1_Start();
ADC_DelSig_1_StartConvert();
int8 output;
/* Place your initialization/startup code here (e.g. MyInst_Start()) */
for(;;)
if(ADC_DelSig_1_IsEndConversion(ADC_DelSig_1_RETURN_STATUS))
output = ADC_DelSig_1_GetResult8();
//IDAC8_1_SetValue(75);
/* Place your application code here. */
You need to just declare the variable above the main()
Eg:
int8 output;
main()
Your application
Bragadeesh
Bragadeesh
