Re: PSoC Creator Debugger Watch Memory Location
JoBr_1593366
100 sign-ins 50 questions asked 100 replies posted
Is there a way to view the values of complicated macros, like USB_ARB_EP_BASE?
Ekta_N
750 replies posted First like given 250 solutions authored
Hi @JoBr_1593366
You can store the value of the macro in a variable and add a variable breakpoint or if the macro ultimately stores the value at a physical address you can a memory watchpoint to monitor the value at the address.
To add a memory watchpoint:
  • From the PSoC Creator Debug menu, select New Breakpoint > Memory Watchpoint...
  • In the Breakpoints window New menu, select Watch Memory...
In a similar way you can also add a function or a variable breakpoint.
Best Regards
Ekta
Ekta_N
Hi @JoBr_1593366
Best Regards
Ekta
