JoBr_1593366
Level 5
50 questions asked 100 replies posted 50 replies posted
Level 5
Is there a way to view the values of complicated macros, like USB_ARB_EP_BASE?
Ekta
Moderator 250 solutions authored 100 likes received 250 sign-ins
Hi @JoBr_1593366
You can store the value of the macro in a variable and add a variable breakpoint or if the macro ultimately stores the value at a physical address you can a memory watchpoint to monitor the value at the address.
To add a memory watchpoint:
  • From the PSoC Creator Debug menu, select New Breakpoint > Memory Watchpoint...
  • In the Breakpoints window New menu, select Watch Memory...
In a similar way you can also add a function or a variable breakpoint.
Best Regards
Ekta
Ekta
Hi @JoBr_1593366
Best Regards
Ekta
