RaSh_3782726
10 replies posted 10 questions asked 5 replies posted
I have some problem of sending or receiving data for rs232 port in Psoc 5lp development kit.
Have some solution regards this?
connection of this I am using re232 to usb cable. and also detected the port in my pc. But I can't communicate with serial terminal.
Which example I preferred for this?
I am using UART_Rx programme for that but I could not receive any data.
But I am using KIT-050 and it is for 059.
Can you please give the hardware connection?
Is there any connection jumper?
I am connected simply rs232 to usb but I did not get any output.
odissey1
Level 9
Level 9
ratangshah,
Check example project here
UART string reception garbage value
/odissey1
The CY8CKIT-050 has an RS-232 connector with a TTL signal level converter.
Rx (TTL) and Tx (TTL) can be found on connector P5.
You need to connect the pins of the P5 connector to the pins of the UART component.
