Hello All,
We are using CY8C24423A controller PDIP package and trying to program hex file. I am not able to program it and getting error.
What is part should select for PDIP package, as I am not able to get exact part no - CY8C24423A-24PXI in programming tool ?
Hello @PranayU ,
From the screenshot you have provided, I can see that the device is correctly selected, protocol is ISSP which is also correct, voltage is 5V, also correct and connector is 5 pin, also correct.
Kindly try turning on Autodetection and see if that helps. Otherwise you may have to check cables, connections and do a swap test to see if device is faulty.
Sampath
Hello @PranayU ,
Sampath
