David_Zhang
100 replies posted First solution authored 50 replies posted
    where can i find register datasheet and firmware API specification doc; thanks;
HeLi_263931
Level 8
Level 8
  • there is the PSoC5LP register TRM
  • all the other API is documented in the specific component data sheets (and the common system API doc can be found in Creator under help)
HeLi_263931
Level 8
Level 8
