PSoc creator project specified the device as "CY8C5488AXI-LP120" and so did in the bootloader. Generated the hex file. but the PSoC programmer identified the device as "CY8C5667AXI-LP040" automatically when hook up the programmer and the PSoC chip on the board, and no way to change the device manually. Of course the programming reported "programming terminated" because "the hex file does not match with the acquired device".
How this happened and how to solve it in PSoC creator?
Hello.
You can select your target device manually by clicking OFF beside AutoDetection. Then, select PSoC Device Family and Device using the drop down menus (shown as greyed out in your screen capture above).
That said, PSoC Programmer has detected 5667 device and PSoC Programmer (in general) doesn't lie.
So, either you have pointed PSoC Programmer to the wrong hex file, or you have a bogus PSoC part.
Can you provide a good photo of the device so we can see the markings.
Something you can try to program the device from within Creator.
From Creator window, open the project, Debug menu, select Program. Answer the questions as they pop up. You need to Acquire and Connect (sometimes that just happens automatically).
Let us know your results.
Hello.
solved, thank you.
