Is there a way to connect 2 net (in the top design) that have different name.
I've got a net call PWM_Clock in a sub sheet with my PWM stuff.
And I want to be able to connect it with another net PWM_BLDC_Clock.
But I would like to keep the name. So I need to have the 2 name net in the same sheet to do that, and I havn't succeeded to do that.
thanks for any help
roboteux,
To connect two wires (buses, nets) with different names, one can use the Dummy component:
The Dummy: empty component for digital bus routing
Just place a component between the nets.
/odissey1
roboteux,
You cannot connect two digital nets with different names across pages. However, you can create a net on one page and have it connected to a net on another page (with the same name).
Question: Is PWM_Clock and PWM_BLDC_Clock their own driven clocks?
If so, you can use a Multiplexer or Virtual Mux for controlling which clock is used.
I not, you can use a Buf component. There is a single propagation delay through it.
If you can tolerate a single BUS_CLOCK delay, you can use a Sync or UDB Clock Enable component.
roboteux,
/odissey1
