AlVa_264671
25 sign-ins First like given First like received
Hi There !
I have some issues to implement  "double sqrt (double ) " in code.
My code include  math.h but the buildin give me the attached info.
Any suggestion?
ADSW
50 likes received 250 sign-ins 50 solutions authored
Hi @AlVa_264671 ,
Please adding "m" to additional library,
I hope this KBA: Using Math Functions in PSoC® Creator™ for the PSoC 4 or PSoC 5LP GCC Compiler – KBA93076 can help you.
warm regards
ADSW
Arpit_S
50 likes received 250 replies posted 100 solutions authored
Hi @AlVa_264671 ,
Let me implement the same at my end and share the project with you. I see you have tagged PSoC 5 in the thread, So I will implement the same with PSoC 5 device
Thanks!
Kind Regards
Arpit Srivastav
Arpit_S
Hi @AlVa_264671 ,
The error says cannot find Imath.h, I tried below mentioned code, I didn't get the build error.
#include "project.h"
#include <math.h>
#include <stdio.h>
CyGlobalIntEnable; /* Enable global interrupts. */
double x = 64;
double result;
result = sqrt(x);
/* Place your initialization/startup code here (e.g. MyInst_Start()) */
for(;;)
/* Place your application code here. */
Let me know if this helps
Kind Regards
Arpit Sirvastav
ADSW
Hi @AlVa_264671 ,
warm regards
ADSW
ADSW
Thanks so much.
