eeEn_4618901
Level 4
Level 4
I want to make my own project on the pcb card.  Which circuit elements should I use?
I made a pcb card with Psoc 4. I want to make sure which circuit elements to use for Psoc 5lp CY8C5888LTI-LP097 QFN68.
Vasanth
You can always kit schematic as reference on what components to use as they are tested and proven. Kindly refer PSoC5 Hardware Design Considerations document. The document will have suggestions on how your hardware should be made according to your use case and suggestions on schematic and layout.
Vasanth
Vasanth
Vasanth
Can I just use the capacitors in the following circuits?
Vasanth
Yes you can. Hardware design guide covers what pins use for each of the power supply pins too.
Vasanth
