Cypress PSoC 5LP Prototyping Kit Measurement Electronics: hardware and software eBook : Magda, Yury:...
If someone has this book can they review it ??
Should I buy this if I'm a beginner?
PSOC5 LP MCU
I have not read the book. However, from the excerpts, it seems that it mostly repeats examples already provided by the Cypress. If your only goal is to use it for a class, then it is better to use project examples, provided with Creator IDE. Just open File->Code Examples and select PSoC5LP family:
Each project is annotated and has App Note alongside.
It is also educational to watch training videos by Cypress. The PSoC5LP training videos are no longer available on Infineon, but you can find many on YouTube (search psoc+5lp+tutorial). Since PSoC5LP is dated, you should dig for older videos
How to blink an LED using Firmware with PSoC 5LP
How to Blink an LED Using a PWM Component with PSoC 5LP
How to Get Started with an ADC, DMA and VDAC Example Projects for PSoC 5LP
How to Get Started with an Opamp Example Projects for PSoC 5LP
How to use the WaveDAC with PSoC 5LP
How to Create an Analog Filter with PSoC 5LP
How to Create an Analog Alarm with PSoC 5LP
PSoC Creator Tutorial - Working with Clocks
PSoC Creator Tutorial - Importing and Copying Components
Non-Cypress video
PSoC Microcontroller Tutorial - Analog/PWM
PSoC Microcontroller Tutorial - Interrupts/Sleep
One can dig out PSoC5 App Notes on new Infineon website
https://www.infineon.com/cms/en/search.html#!term=PSoC5%20App%20note&view=all
But many can be also found here
http://www.bdtic.com/en/cypress/psoc-creator-integrated-design-environment-ide
https://community.element14.com/products/devtools/technicallibrary/m/files/12033
- PSoC5 training video
Non-Cypress video
