I am very new with PSOC and embedded programming. I have been having issues with CapSense proximity sensing. I have created a proximity widget and assigned it a sensor. I have other capsense buttons on my board which have been configured as well and are working. I have not been able to figure out how to use the tuner with a proximity sensor. I read that all widgets are enabled by default except proximity widgets. How do you manually enable a proximity widget so you can use it in the tuner? Below is the part of my code that is dealing with CapSense. Thank you for your help.
-Walt
(This portion of code is in my main)
/* start tuner operation */
CapSense_1_TunerStart();
CapSense_1_EnableSensor(CapSense_1_SENSOR_PROXIMITYSENSOR1_0__PROX); //Not sure where to put this??
for(;;)
CapSense_1_TunerComm();
/* end tuner operation */
PSoC 3
