Hi All,
OS: Windows 10
IDE: PSoC Creator 4.1
CPU: PSoC 5
I tried to build a project using PSoC Creator 4.1 but it fails the build with the following error:
arm-none-eabi-as.exe -mcpu=cortex-m3 -mthumb -I. -IGenerated_Source\PSoC5 -alh=.\CortexM3\ARM_GCC_541\Debug/CyBootAsmGnu.lst -g -o .\CortexM3\ARM_GCC_541\Debug\CyBootAsmGnu.o Generated_Source\PSoC5\CyBootAsmGnu.s
mkdepend: error: unknown opt = -
The command 'mkdepend' failed with exit code '1'.
When I share the project with my colleges, they have no problems building it. I can load a sample project and build them.
I've tried reinstalling PSoC Creator, removing any old projects, and generally trying to get my computer back to square one when it was working.
Any suggestions would help. Thanks.
PSoC 5 Device Programming
PSoC 5LP
- build error
- mkdepend
I found the solution.
It seems PSoC Creator has a problem with single quotes ' in path names. Lo and behold, I has a single quote in my path name. Changed the name and, presto, problem solved.
