PSoC Creater 4.4 will program my CY8KIT-059.
However, Programmer 4.00 will not recognize the device.
However, Programmer will detect my CY8KIT-147.
What must I do to get Programmer to detect the CY8KIT-059 ?
PSoC 6 MCU
Since you are using the PSoC Creator IDE, I thought the "programmer" you were using was a PSoC Programmer.
From the description of "Programmer 4.0", I understood that it is Cypress Programmer, not PSoC Programmer.
Cypress Programmer does not support CY8CKIT-059 for PSoC5LP.
If you want to use programmer for PSoC5LP series, you need to use PSoC Programmer.
Part of the PSoC 4 series is supported by Cypress Progarmmer and the Modus Toolbox IDE.
PSoC Programmer is installed at the same time as PSoC Creator is installed.
Cypress Programmer Release Notes URL
https://www.cypress.com/file/521221/download
Note : Nowadays, "Cypress Programmer" is also called "Infineon Programmer".
