Hi All,
I am using CY8CKIT-059 prototype kit. that is programmed by Connecting the kit to the computer through the PCB USB connector J10. here Kitprog is used to program the CY8C5888LTI-LP097 target Device. here
1) I just want to know is there any bootloader on this kit for programming? how we are able to program the CY8C5888LTI-LP097 IC by using kitprog?
2) A board design that is having multiple (5-10) CY8C5888LTI-LP097 IC. How I can program these multiple cypress IC in the easiest way without using any kitprog/miniprog just by using PC(computer) ?
AbPa,
There are few threads discussing this problem
Programming two or more PSoC onboard at the same time.
How can I program multiple PSOC 4 Devices (and maybe more) at once?
Programming multiple PSoC 5LPs on one PCB with JTAG
/odissey1
AbPa,
/odissey1
