KaSo_1669721
Please help me
I've declared and defined the global variable...let say vrc and at the begining of main()
I've redefined vrc but when I print out the result, garbage was printed...why?(please refer file isg-no-enc-test-handle3.txt)
Any help is appreciated
Kamari
The sprintf() buffer variable "dbg" is defined quite too small. So some parts of your sram gets overwritten.
Is there a reason for the large stack size of 0x1200 bytes?
Bob
Bob_Marlowe
Level 10
Level 10
Can you please post your complete project or a shortened version that shows the error so that we all can have a look at all of your settings. To do so, use
Which PSoC kit are you using? CY8CKIT-0??
Bob
Thanks Bob…I resend here
Thanks in advance for your help
Kamari
Bob
Thanks Bob
I’ll try today
Regarding stack size, actually no reason, just try n error
Thanks Bob
Everything back to normal now
Thanks again
Kamari
