Hi! I'm trying to transfer example code (CE85976) for CY8C22545-24AXI controller(it uses SmartSense2X) into CY8C20536A-24PVXI controller(it uses general SmartSense). It needed to turn on and off 3 leds with 3 sensors. Use PSoC Designer 5.4.
The compiler tells me, that identifier "SmartSense_bScanComplete" is undeclared. Line editor doesn't know such an identifier at all. May be I can substitute it with something similiar? There is the part of the code:
while(1)
if(scanningFlag==SCAN_FIRST_SENSOR)
capSensorNo=0 ; // initializing to scan first sensor
SmartSense_ScanSensor(capSensorNo);
scanningFlag= FIRST_SENSOR_SCAN_DONE;
else if(scanningFlag == FIRST_SENSOR_SCAN_DONE)
if(SmartSense_bScanComplete & SmartSense_SCAN_COMPLETE) //checking for sensor scan is complete
SmartSense_bScanComplete &= ~SmartSense_SCAN_COMPLETE ; // clearing the sensor scan complete flag
SmartSense_UpdateSensorBaseline(capSensorNo); // Run baseline filter
SmartSense_bIsSensorActive(capSensorNo); // updating the SmartSense_baSnsOnMask[]
capSensorNo++; // increment to scan next sensor
