We're designing a new product based on CY8CKIT-033A. We use the midi interface to control an application running on iPhone device.
After the last update to iOS13 midi interface doesn't work properly. The midi interface is recognized by the app only the first time. After a disconnection there's no way to restore the midi link. Only a swith off and switch on of the iPhone restore the link for one shot. Before the iOS update everything worked fine. Does Cypress provide to fix this bug?
Thank you
Mario Caramanico
Hello Mario,
Can you please attach your project. This will help us to recreate the issue at our side and get further inside of the problem.
Best Regards
Ekta
Hello Ekta,
actually we’re using the default software for the development kit (see attachment). We connect a midi pedal board on the Midi In1 of midi interface and analyze the midi incoming signal with the app “midi scope” version 1.4 running on an iPhone 6s with iOS 13. With the same setup but with iOS 12 we had always a right functionality in term of connection between development kit and iPhone and in term of received data. After the update to iOS13 some problem arise.
In order to analyze the connection robustness we disconnect/reconnect the power supply on J306 of the development kit.
We have two sort of failure:
· the iPhone shutdown alone
· the development kit get stuck with the display freeze on “Inizializing iAP”
We’re completely available to provide any further information you believe helpful
Mario
Da: EktaN_26 <community-manager@cypress.com>
Inviato: venerdì 4 ottobre 2019 08:26
A: Mario Caramanico <mario@markbass.it>
Oggetto: Re: - Problem with dev kit CY8CKIT-033A midi interface
<http://www.cypress.com>
<https://community.cypress.com/?et=watches.email.thread> Cypress Developer Community
reply from EktaN_26 <https://community.cypress.com/people/EktaN_26?et=watches.email.thread> in PSoC 3 - View the full discussion <https://community.cypress.com/message/211043?et=watches.email.thread#211043>
Ekta,
hereafter a picture of the setup
Mario
Hello Mario,
There are several iOS updates after this thread was created. Can you please confirm if you are still facing this issue with the recent updates?
Best Regards
Ekta
