JoMa_4772696
I've been trying to program a PSoC 5 with a Python script. I keep getting the following error when pp.PSoC3_WriteNvlArray() is called.
Exception has occurred: com_error
(-2147417851, 'The server threw an exception.', None, None)
  File "<COMObject PSoCProgrammerCOM.PSoCProgrammerCOM_Object>", line 3, in PSoC3_WriteNvlArray
File "C:\SVN\New Test Procedures\TestStand Test Sequeces\Python Scripts\Python_Ex.py", line 269, in ProgramNvlArrays hResult = pp.PSoC3_WriteNvlArray(arrayID, hexData);
File "C:\SVN\New Test Procedures\TestStand Test Sequeces\Python Scripts\Python_Ex.py", line 465, in ProgramAll hr = ProgramNvlArrays(enumSonosArrays.ARRAY_NVL_USER)
File "C:\SVN\New Test Procedures\TestStand Test Sequeces\Python Scripts\Python_Ex.py", line 603, in ExecuteWithFilename hr = ProgramAll()
File "C:\SVN\New Test Procedures\TestStand Test Sequeces\Python Scripts\Python_Ex.py", line 620, in <module> portStr = "KitProg/030E0BF302098400"
Thanks!
Rakshith
Hi JoMa_4772696​,
I was able to program PSoC 5LP device using the example Python scripts provided as mentioned in this thread - KitProg3 PSoC5 programming using python
Can you please let us know the entire procedure followed to program the device? Also, can you attach the entire log of the process?
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
Rakshith
Hi JoMa_4772696​,
Thanks and Regards,
Rakshith M B
Thanks and Regards,
Rakshith M B
