So, I have wrote this basic program for data to be seen in APP(MIT) using hc05 module. I cant find the problem can you help me with this.
scrolling graph in app's aia file.
p.s : AT address of the Bluetooth module is given.
Hi @Ashish25,
I see you have used UART component and are expecting communication with HC-05. I suggest you go through our UART code example(CE) for PSoC5LP - [CE document ] [CE zip file].
I see that you haven't enabled global interrupts. You can do that by using the following macro:
CyGlobalIntEnable;
The "RX - On Byte Received" interrupt source is active in your project. You may want to utilize it by writing an ISR - refer to the code example for more details.
Nikhil
Hi @Ashish25,
CyGlobalIntEnable;
Nikhil
