I'm trying to read the data sent from a HC-SR04 sensor in the computer terminal using TeraTerm. Before I started doing this, I made sure everything was working well in my program and the sensor and so it does: I used an LCD display and everything is fine. The problem is that I don't know how to send this data using the USBUART (CDC Interface).
The project can be found attached to this message. I am using the CY8CKIT-050 PSOC 5LP DEVELOPMENT KIT Could anyone please help me?
Thanks in Advance.
PSoC 5LP
As I could not open the attached project,
I reused my HC-SR04 project for CY8CKIT-059
and modified it for CY8CKIT-050 and USBUART.
During the task, what I noticed were
(1) I needed to add "USBUART_cdc.inf" file which was with the original application note.
(2) To use USBUART just like UART, I needed to do
USBUART_Start(USBFS_DEVICE, USBUART_5V_OPERATION);
/* Wait for Device to enumerate */
while(!USBUART_GetConfiguration());
/* Enumeration is done, enable OUT endpoint for receive data from Host */
USBUART_CDC_Init();
TeraTerm log
moto
