AlVa_264671
Hi There
I am in trouble with the attched project regarding the pins folder.
Most of the pins folders doesn't appear in PSoC5 generated source after compile the project.
SrikanthD_56
First comment on blog 100 replies posted 50 solutions authored
Since all the pins in your design are connected through Wire Tool (HW connection), PSoC Creator did not generate the code for those pins (as it's unnecessary).
However, if you still want to generate APIs for Pin component, uncheck the 'Suppress API Generation' option in Configuration window as shown in the below image.
SrikanthD_56
Hi srds
Thank you very much.
I didn't notice  this feature in PSoc 4.1.
Redgars
Alex
