Dec 07, 2021
08:46 PM
Dec 07, 2021
08:46 PM
Hi everyone... I'm working with the DS18B20 temperature sensor and I'm using One-Wire Protocol, the project is working well but I have a question:
Why when I use any of the following pins: P0[2], P0[3], P0[4], P3[2], in order to read the sensor's signal, the display shows me 0.00 ºC, but when I use any other GPIO Pin the display shows a correct temperature value?
There is something I'm missing something about those pins? Any caracteristic that doesn't allow them to function in data sensor reading?
Thanks in advance...
Labels
PSOC5 LP MCU
03:50 AM
Dec 08, 2021
03:50 AM
Hello.
Assuming you are using KIT-059 (missing details of your setup), the 4 port pins you identified have 1uF capacitors attached to them.
Good luck with your project.
