Hello @LuSa_1231216 ,
I suppose this issue is related to PSoC1, RS485 transceiver High Z Ro output (when enable is high, see table), does have anyone a solut...
Does adding an external pull-up to MAX485-RO resolve this issue? The Rx /P1[6] going low and come back high again is recognized as a stop bit, and the interrupt is generated internally. It is pending till you enable interrupts in the UART User Module.
You can try one of two things:
- Set the initial value of P1[6] to 1
- Connect P1[6] to another free GPIO, configured as Resistive Pull Up.
Sampath Selvaraj
After enabling and servicing the interrupt, maintain RX_IN high. Then disable the interrupt, and enable it again. Let me know if you see and interrupt being generated again. Read the INT_CLRx registers to see if the interrupt is active before it is disabled.
Sampath
The problem is always the same, i take a snapshot -> yellow is the RX in Data signal and blue is the RX8 interrupt , the peak interrupt is after +/- 250µs and RX8 enable and rising edge. If i take longer times to disable and enable = longer time positive Rx signal, but the same result .
Sampath Selvaraj
