We use the UART component of PSoC5LP.
The UART component has "UARTRX-On Byte Received" enabled.
Interrupt is generated by receiving byte data,
The following processing is performed in the interrupt.
/* UART Rx interrupt routine */
while ((UART_1_ReadRxStatus() & UART_1_RX_STS_FIFO_NOTEMPTY) !=0) {
uint8 data = UART_1_GetChar();
In this process, data cannot be obtained normally by the _GetChar() API.
However, it can be received normally if modified as follows.
uint8 data = UART_1_GetReadRxData(); // Change API
In this case,
What is the difference between Get_Char function and ReadRxData function?
I confirm for the contents of each API,
The GetChar function checks the status flag, and the ReadRxData function does not check the status flag.
I think the difference is only checking the status flag.
Does this difference affect the behavior?
PSoC 5LP
MaMi,
The issue you are seeing is that GetChar() is primarily designed to be used in a Rx polling strategy.
If you want to use GetChar() try getting rid of your API call to ReadRxStatus(). Since GetChar() reads the RxStatus register, at a minimum it is redundant to your ReadRxStatus() call.
Len
