I have an op amp component buffering an internal 1.024V reference. I have connected a 1.2kΩ on the output. The voltage I get is 700mV instead of 1024mV. I need to source and sink 20mA from this pin. How can I do it?
Kumar
PSoC 5LP
SaKu,
Please make sure that you connected resistor to the Opamp direct output pin (P3_6, P3_7, P0_0, P0_1). Direct pins have low resistance, while other pins may have 250-500 oHm resistance path from Opamap to the resistor. So the resulting voltage will be something like V = 1.024V x 1200 / (500 + 1200) = 0.723 V.
Keep in mind that even direct connection has some resistance, and Opamaps have some bias offset, so the output voltage will not be exact 1.024V.
You can find discussion of the same issue here:
Re: How to outputting internal 1.024V Vref inPSoC 5LP
/odissey1
KIT-059 annotation component: KIT-059: annotation component for CY8CKIT-059 PSoC5LP Prototyping Kit
1: If you configure the Opamp as a follower, the internal 1.024 which be output should also be 1.024v.
2: connect the resistor: 1024mv/20mA
SaKu,
/odissey1
Thank you very much odissey1. My problem is solved.
Kumar
