Please correct some on-line information for PSoC5LP, which is currently categorized under 8/16 bit MCU. ???
I recommend to provide links to active PSoC5LP information in two locations:
- PSoC5LP is a 32-bit PSoC MCU https://www.infineon.com/cms/en/product/microcontroller/32-bit-psoc-arm-cortex-microcontroller/
- PSoC5LP is also a 32-bit Legacy MCU https://www.infineon.com/cms/en/product/microcontroller/legacy-microcontroller/legacy-32-bit-mcu/
PSoC 5 (rebranded PSoC 5LP) currently appears to be misclassified as an 8/16 bit MCU @ https://www.infineon.com/cms/en/product/microcontroller/legacy-microcontroller/legacy-8-bit-16-bit-m...
I also recommend clarifying the status of the obsolete versions of PSoC5 by moving the directory under PSoC5LP or into some obsolete product information holding location to ensure customers find PSoC5LP first or are clearly informed PSoC5LP is the current product. PSoC5 (The Obsolete versions) are currently mapped to https://www.infineon.com/cms/en/product/microcontroller/legacy-microcontroller/legacy-32-bit-mcu/pso...
Greg
PSoC5 LP MCU
Hi @GrCa_1363456 ,
You are correct, PSoC 5LP is misclassified as a 8/16 bit MCU.
I will raise an internal ticket to get this rectified.
Your suggestions have been noted.
Thank you for using our products and feel free to let us know of any issues or suggestion you may have through the community.
Warm Regards
Alen
Hi @GrCa_1363456 ,
Warm Regards
Alen
