We are considering using the Sensor Auto Reset function of CapSense component.
The data sheet has a description that is set 5 to 10 seconds.
Is it possible to change this time?
We would to set more than 10 seconds.
PSoC 5LP
Hi
It is not possible to change the time for Sensor auto reset.
You can however, achieve this through firmware by calling the CapSense_InitializeAllBaselines API if the sensor is active for a certain period.
You can use systick timer to measure the duration for which sensor is active and call the API when certain amount of time has elapsed.
Please refer this KBA for details on how to use systick timer to measure button press duration.
Measuring Duration of CapSense Button Press Using SysTickTimer - KBA226863
Thanks and regards
Harigovind
