MarcelKrisman
Hello all,
I would like to know what would be quickest migration of the PSoC device towards a newer PSoC device which
is recommended for new designs (full long term production) ,
and where the debug-tooling & progamming tooling is fully available.
Main parts that would need migration are:
CY8C29566-24AXI
CY8C27433-24SXI
Any help / suggestions are more than welcome.
Thanks and regards,
Marcel Krisman.
Bob_Marlowe
Level 10
Level 10
Download and install PSoC Creator 4.4 and get acquainted with the new IDE
Start any of the PSoC4 example projects and check the availlabe components with your  PSoC1 requirements. There is a datasheet for EACH component, so you can verirfy the performance.
Get hands on a prototype board or a Pioneer prototype, both of them have got an integrated debugger
Happy coding
Bob
Bob_Marlowe
Level 10
Level 10
Happy coding
Bob
MarcelKrisman
Hello Bob,
Thanks for you feedback.
You are referring to PSoC 4 example projects.
So it is adviced to use PSOC 4 devices instead of PSoC 3 or PSoC 5 or ? for a PSoC1-redesign?
Thanks and regards,
Marcel Krisman.
Marcel,
I would advise that you directly contact an Infineon Sales Representative in your area.
A choice of a replacement PSoC will depend, in part, on the PSoC1 resources being used and your projected volume in the next few years.
Infineon has a production plan for each of their legacy parts (PSoC3 and PSoC5) and their other parts going forward.  Depending on their production plans and your anticipated product life plans will help to inform your decisions.
Len
Bob_Marlowe
Level 10
Level 10
PSoC 3 and 5 differ only in the underlying processor. The PSoC3 has an a bit outdated 8055 CPU (desigbed in 1980) which has its limits. The PSoC 4 and 5 have got an 16 bit wide ARM Cortex M3 CPU which is a lot faster than the  PSoC1's 8 bit CPU. The PSoC 4 components are easily to design with and cover a wide range. When you specify the components you used in your PSoC 1 design we will be able to check compatibility.
Bob
MarcelKrisman
Hello Bob,
In the PSoC1 device CY8C29566-24AXI we use:
29x digital GPIOs
2x analog inputs
1x SPI-interface
1x I2C interface
In the PSoC1 device CY8C27433-24SXI we use:
14x digital GPIOs
1x I2C interface
Please advice on "replacement" parts.
I don't see an ADC available in PSOC4 parts...
Thanks for advice.
Marcel Krisman.
Bob_Marlowe
Level 10
Level 10
When you open a project in creator there is the option  Project->Device Selector which shows number of pins blocks etc.
You should select the 4200M family which has all you need. ADC is a 12-bit SAR with an input-multiplexor for more than 4 channels.
give it a try
Bob
