stsm_296211
10 replies posted 5 replies posted 5 questions asked
I'm using the CY8C24894-24LTXI on a board mainly as a simple USB interface to the outside world (which can be both windows or embedded hosts). The PSoC1 is always a device. I recently have enumeration problems that pop up. In looking closer at the PSoC1 side, the D+ pullup measures much higher than the spec 1.5K, closer to 2k. This appears to add to the startup issues. There's not much in the Developer's USB wizard that I can see would bias the D+ pullup value.
Has anyone seen this issue, or any tips on what we might be doing on startup that would effect the D+ pullup? This is not a new board (like over 10 years), so nothing has changed in years.
Thanks - Steve
SampathS_11
250 sign-ins 250 solutions authored 5 questions asked
Hello Steve,
Kindly adhere to the spec 1.5K. Moving away from this spec will result in a different logic level which may not be recognized by the host.
Sampath Selvaraj
SampathS_11
Hello Steve,
Sampath Selvaraj
