salmi
5 replies posted First like given First like received
Recently if I open PSoC Designer normally (not as admin) I can open projects but the top file menu ribbon is not available and I can't do any build or debugging.
If I run Designer as admin then the project does not open and I get this error:
has anyone had this problem? Any help is appreciated.
MuhammadNanda_K
50 solutions authored 250 sign-ins 250 replies posted
Hello @salmi ,
I can do compilation using PSoC Designer 5.4 on Windows 11:
For the attempt to fix your issue, may you kindly try below steps:
  1. Complete uninstall the current PSoC Designer software in your Windows 11.
  2. Download from the archive page, the last file listed on the section "Design Support" tab "Development Tools":
    The downloaded installer file should be >400 MB.
  3. On a window in installation process, there will be a question for "Complete" installation or other choice, please select the Complete installation.
  4. After the installation success, launch PSoC Designer 5.4, then see if there is any build menu and can build successfully.
Please kindly update your status after trial. 🙂
Thank you and regards,
Muhammad Nanda
MuhammadNanda_K
Hello @salmi ,
Which PSoC Chip / Dev Board do you wanted to use ?
Since this PSoC Designer software is discontinued in status.
Muhammad Nanda
salmi
Hi. Thank you for your response. I am using CY8C29866. I have been using them for a while on my custom boards.
MuhammadNanda_K
Hello @salmi
I am still checking PSoC Designer archive here:
https://www.infineon.com/cms/en/design-support/tools/tools-archive/psoc-designer-archive/?gatedConte...
for which version can be used correctly without that your issue.
Meanwhile, may you kindly inform which Windows OS version do you use ?
Muhammad Nanda
Thank you for checking. I am using Windows 11.
MuhammadNanda_K
Hello @salmi ,
Muhammad Nanda
salmi
Hi Muhammad,
Thank you for troubleshooting. uninstalling and installing Designer fixed the problem.
MuhammadNanda_K
Hello @salmi ,
You are welcome.
Good to know that your issue has been solved. 🙂
Then, I will close this discussion thread.
If you have any other issue in the future, please kindly do not hesitate to create new thread.
Muhammad Nanda
