If we are doing a project regarding Temperature Sensing which version of Creator would be more helpful ??
PSOC2.1 or PSoC2.0 ?
Are there Application notes available regarding Creator version2.0
PSoC 3
Generally speaking always use the latest revision of Creator IDE,
as each release is comprised of bug fixes and enhancements.
In so far as temperature measurement the following is an apnote
http://www.cypress.com/?rID=49052
http://www.cypress.com/?rID=42993
Regards, Dana
... and when you consult your Cypress Update Manager, you'll see that there is a new version of Creator 2.2 which you may download and install. As an extra there is a new temperature sensing module.
Bob
If your sensor is "remote", meaning a long copper run, consider using
current based integrated sensors, like LM334. There are also sensors that can
compensate for series R effects, several manufactuerers, TI, ON....
Do not forget to make compliance calculations for the sensor based on length
of run, current, and Cu wire size.
Regards, Dana.
