Need software for Windows 10 64-bit that can program PSoC 1 family, CY8C27443 parts. I plan to buy CY8CKIT-002 MiniProg3. I installed PSoC Programmer software 3.29.1 to make sure it will work with MiniProg3. But when I try to select the Device Family, then the specific device, I can't find anything close to CY8C27xxx.
What is the correct Windows software for use with MiniProg3 and CY8C27443?
PSoC1 MCU
- programmer
Hi @KOlinger ,
Kindly follow the procedure illustrated in How do I program CY8C29666-24PVXI? with the device family set to "27x43".
Sampath Selvaraj
Hi @KOlinger ,
Sampath Selvaraj
Thank you. After receiving my PSoC MiniProg3, PSoC Programmer 3.29.1 was easy to use. After clicking the ISSP button as you suggested, and using the default AutoDetection = On setting, it automatically detected the correct PSoC family and specific part, CY8C27443.
