xiha_4819631
10 sign-ins 5 replies posted 5 questions asked
hi,
i use the PSoC Designer  5.4 ,the mcu is CY8C20234
i connect the MInProg3 to the board ,it can programming,
then i want to start a debug , i click the "debug",but it show below .
and then i found the document about IDE,
but my prj have no  "Debug Mode",
so how start a debug?
thanks.
Roy_Liu
First comment on blog 1000 replies posted 500 solutions authored
MiniProg3 does not support debugging for PSoC1(CY8C20234 is PSoC1 device) devices, furthermore, PSoC1 device does not support on chip debugging itself. To understand more about PSoC1 debugging you can refer to AN73212 - Debugging with PSoC® 1 (cypress.com)
Essentially, you will need build prototype board with a On-Chip-Debugger (OCD) device and In-Circuit Emulator(ICE).
PSoC1 devices are sort of old controllers, you may want to consider new PSoC family devices such as PSoC4 if you have a chance.
Roy Liu
Roy_Liu
Roy Liu
