PSoC Designer Build Error (ilibw.exe)
I am using PSoC Designer 5.4 SP1 on windows 10 and I amgetting an error dialog "ilibw.exe has stopped working" when I try to generate/build the project.
The output tab shows the following information:
Starting MAKE...
creating project.mk
lib/adcinc_1.asm
lib/adcinc_1int.asm
lib/lcd_1.asm
lib/pga_1.asm
lib/psocconfig.asm
lib/psocconfigtbl.asm
make: *** [lib/libPSoc.a] Error 255
PDProject1 - 1 error(s) 0 warning(s) 02:57:29
You can find the project file attached to this thread. Can you please provide a solution?
