ChRo_1954501
I am looking for help on programming psoc with Cypress MiniProg3, using Jtag.  I am evaluating the CY8C5888LTI-LP097.  I would like to find out which pins to hook up to?  I also like to know what type of file to generate for JTAG programming ?  Can you also look into how to incorporate a boot loader into the JTAG programming ? Which type of interface does the bootloader support? Can you specify the pin outs, and generate the loadable file for updating the application?
AnkitaS_51
You can look into schematics of CY8CKIT-059 which is CY8C5888LTI-LP097 based at this link-
http://www.cypress.com/documentation/development-kitsboards/cy8ckit-059-psoc-5lp-prototyping-kit-onb...
The J5 connector on CY8CKIT-059 is available for MiniProg3 to have JTAG programming for the device.
For understanding bootloader in PSoC, you can go through this AN, which will be very helpful-
http://www.cypress.com/documentation/application-notes/an73854-psoc-3-psoc-4-and-psoc-5lp-introducti...
AnkitaS_51
