I want to implement a USB UART communication between my CY8CKIT-059 and my PC. can any one share me the complete project file of a simple example project along with the steps described in a PDF
ispn:39618:1:0
l1:314:1:0
I believe I've made that effort 'simple' for you.
I made a custom component called "Term". It combines the standard UART and the USB UART into one component. You get to select which one you want to use at design-time. Additionally if you select the USB UART, you can use UART-style API commands to send and receive data and query statuses.
Here's a link to the thread with the uploaded code for the component, component demos and PDFs describing the component, demos and how to install custom components in your Creator IDE.
Terminal-Support-Component-Library
