Jun 14, 2017
05:38 PM
Jun 14, 2017
05:38 PM
What is the best method to access the USB CDC buffer in real time? It has been no problem at all transmitting packets around 1kB, however, the API accessors seem to only update upon the completion of a full packet.
The USB CDC output is limited by memory, whereas the CDC input buffer is limited to 64kB.
I have source code to attach for reference if needed.
I also understand that this task is best suited for isochronous transfer, but there is an old driver used on the host side that is necessary.
Labels
PSoC 5LP
