This is what I'm trying to do.
1) PSoC controls the clock as I2C Master and sends data to the I2C Slave - endpoint.
2) Right after the step 1 is completed, I2C slave endpoint would become I2C Master, send a START condition and start sending response continuously. As you might have realized, PSoC I2C component should switch to Slave mode to make this work.
I've configured the I2C component in Multi-master-slave mode and I'm able to do Step-1. How do I go about implementing step 2 ? we don't know when EP will switch to Master mode & start sending data. How do I handle this switch and any code examples for my scenario would be very helpful.
This is my code for step 1 when I send data from PSoC master to slave EP :
I'm stuck here and unable to understand how to let EP be I2C master & PSoC as slave and receive data after step1.
Thanks in Advance,
Srinath
PSOC5 LP MCU
Hi @srinathkp ,
Can you please use I2C_Stop API and observe the i2c lines on the CRO to ensure that the bus is released from the PSoC device through which the EP device can capture that.
Kindly refer to the I2C component datasheet to know more about the APIs.
Rakesh
Do I understand it correctly the MASTER1 and SLAVE2 (which will switch to MASTER2) is located within the same PSOC chip ? May I ask why you want to do this ? Are you aware that a SLAVE2 can also send data back to a MASTER1 but that communication is initiated by MASTER1.
Once you change the SLAVE2 to MASTER2, I think you also need to change the original MASTER1 to SLAVE1. If not, you have 2 MASTERS on the bus that both have CLK as output signal so there is a collision.
Hi @pacr_284376 ,
It's not part of the same PSoC chip, it's an external endpoint connected to I2C pins. We want to do this so that the endpoint can become master and send data in different i2c transaction sizes whenever it wants to. It's the requirement.
You're right about this part :
I want to change Master1 to Slave1. How do I go about it ?
PSoC master sends specific data to slave. Slave turns master now, PSoC should detect this (START condition) and become slave.
Hi @srinathkp ,
Rakesh
