Hello dear community,
I want to start a tiny project where I want to interface a PSoC 5LP Kit with an external SPI EEPROM. It shouldn't be a big issue to find an example project as starting point but it seems like things got a bit complicated since Infineon overtook cypress 🙂
What do you think which example project I could use?
PSOC5 LP MCU
Hello @Kronos
We don't have an exact code example demonstrating interfacing PSoC 5LP with SPI EEPROM. I believe that according to your requirement you want to configure PSoC 5LP as SPI Master which will used for writing, reading and configuring the external SPI EEPROM.
I have the attached code examples for PSoC 5LP SPI Master and slave that you can use as a reference for transferring data from SPI Master to SPI Slave.
You will need to edit the code example to transfer the data as per your requirement.
Best Regards
Ekta
Hello @Kronos
Best Regards
Ekta
