I am trying to figure something out and hope someone can help me with this.
I have a project using PSoC 5 LP and emWin library. I have created a screen to display on the 320*240 TFT LCD. Building the project tells me
I have used 91% of flash memory. When I comment out the screen and all API that links to emWin, I see the flash memory consumption is only 0.6%.
1. Is this something that anyone here has come across? Or am I doing something wrong?
2. In order for me to use serial flash, will I be needing Bootloader?
Thank you for all of your help in advance.
The memory requirements are based on the features used in the emWin library. Please find the approximate memory usage of each of the features here: https://www.segger.com/products/user-interface/emwin/technology/emwin-resource-usage/
The component specific resource usage can be found in the component datasheet. For example, the memory usage when using the GraphicsLCDCtrl component is as mentioned below:
No, its not required.
Dheeraj
Dheeraj
Thank you for your response.
So correct me if I am wrong, if I was to use serial flash and use quad SPI to interface serial flash memory chip to PSoC 5 LP, when I build and program the chip it would automatically run the program from this newly interfaced serial flash memory?
Thanks and regards,
Shamili
For memory requirements, we can use the SD Card to store the images. To do so, the sample codes have been attached for reference, courtesy of ShKr_3646021.
Dheeraj
