MiMo_4142486
First question asked Welcome!
The datasheet for the I2C block shows the following code for manual read. However, how can I read from a specific register?
The I2C_MasterSendStart includes the slave address, but I don't see the register address being called out.
Example Code:
status = I2C_MasterSendStart(0x08, I2C_READ_XFER_MODE);
if(I2C_MSTR_NO_ERROR == status) /* Check if transfer completed without errors */
/* Read array of 5 bytes */
for(i=0; i<5; i++)
if(i < 4)
userArray[i] = I2C_MasterReadByte(I2C_ACK_DATA);
else
userArray[i] = I2C_MasterReadByte(I2C_NAK_DATA);
I2C_MasterSendStop(); /* Send Stop */
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
Beta tester First comment on KBA 1000 replies posted
I have posted the following code sample.
https://community.infineon.com/t5/Code-Examples/MCU-Tester-a-Swiss-Army-Knife-for-PSoC-CY8CKIT-059-v...
I hope that you can refer to i2c_utils.[ch]  in that project.
moto
MotooTanaka
Level 9
Level 9
moto
WaMa_286156
First comment on blog 100 replies posted 50 replies posted
Also, some people have had to use the mpu6050, and it has similar setup:
https://github.com/cychu18/PSoC_MPU6050
