I recently asked about a readily available alternative for the CY8C5888LTI-LP097-68-QFN
The answer I received was regarding alternatives for the CYC5288LTI-P090, which is quite different.
The CY85888LTI-LP097-68-QFN is active status but almost impossible to find. I'm looking for recommendations for alternatives to the CY85888LTI-LP097-68-QFN that can be purchased on a reliable basis.
Hi @ScEn_283436
Currently, the PSoC 5LP family has a high lead time. So, could you be more specific about the characteristics you want? I can recommend an alternative part based on your requirement. Once check our Product Page if you wish to choose PSoC 4 or PSoC 6.
Rakesh
Hi @ScEn_283436
Rakesh
