Vladkar
First reply posted 5 sign-ins First question asked
I am using PSOC5 LP in my design and have USB interface with external Windows based application.
Is it possible to use Python script to access to PSOC resourcing (GPIO/I2C/UART) by Python script?
Rakshith
Moderator 1000 replies posted 750 replies posted 500 replies posted
Hi @Vladkar
Can you please let us know if you are referring to the KitProg USB interface or the PSoC 5LP target's USB itself?
I believe for UART you can use the serial python module. If it is the KitProg interface, you could use the examples in this directory as a reference -
C:\Program Files (x86)\Cypress\Programmer\Examples\Protocols\I2C
Thanks and Regards,
Rakshith M B
Vladkar
I am referring to PSoC 5LP target's USB itself.
Vladimir
odissey1
Level 9
Level 9
I believe you should use other modules like IOIO for direct access to the pins using external software. With PSoC you have to develop the entire firmware and software yourself.
