When I use bootloader,I always got "Bootload Failed with Error Code: 0x04003" from host application GUI.
What does 0x04003 mean?Is there an error code table?
The project which you attached is a bootloader project. For bootloading, you need a bootloadable project. Once you build the bootloadable project, you can pass the generated cyacd file from the Host application after entering the device in bootloader mode and the new firmware gets bootloaded. I don't find any issues with the Bootloader. Can you share your bootloadable project also?
Also - you can check:
AN68272 - PSoC® 3, PSoC 4, PSoC 5LP, and PSoC Analog Coprocessor UART Bootloader
http://www.cypress.com/documentation/application-notes/an68272-psoc-3-psoc-4-psoc-5lp-and-psoc-analo...
You may try the sample project provided with this AN and see if you are successful in bootloading.
Here is my project!
