A PSoC3 is a bit slow compared to an 80MHz PSoC5 chip. Fastest interface will be SPI with up to 33Mbitps.
Bob
So in PSoc3 I can "build" SPI interface with 33Mbitps? This is enough for me if we are taking into account that 90% transaction is from proprietary board toward PSoc. If I understand right SPI interface we are building using UDB?
Thank you
Stas
I wasn't talking about PSoC3, but PSoC5. I would suggest you to start a Creator 3.3 project and place the needed interfaces onto the topdesign: SPI interface and an USBUART.
You may use a CY8CKIT-059 for programming and debugging your project.
Bob
I choose PSOC3 mainly for implementing iAP2 protocol. I presume I can implement it in PsoC5 as well. Currently we purchased EVB CY8CKIT-033A based on PSOC3. From yours opinion could we elaborate our solution on this EVB (even with less SPI bandwidth).
Thank you
Stas
The interrupt response time of the PSoC5 is a bit better than for a PSoC3, I cannot tell whether your project will run flawlessly on any platform. Despite the different endianess it is not difficult to switch at a later stage from PSoc 3 to 5.
Bob
From my understanding MFi protocol can run on PSOC5. Please confirm
Thank you
Stas
I am just a poor developer and I am not able to confirm that a special protocol wil run on a special hardware. Estimate and check for yourself. A PSoC5 Prototyping Kit is available at your local distri for just ten bucks.
Bob
