mikes603
First question asked Welcome!
Hi Gents,
 Just curious if anyone out there has experience updating PSOC firmware via I2C from a iMXRT MCU?
I've found these docs:https://www.cypress.com/documentation/application-notes/an86526-psoc-4-i2c-bootloader
But it's not so clear to me what path to go down.. is there code someplace where someone has implemented this with the NXP I2C SDK?
BiBi_1928986
Level 7
Level 7
500 replies posted 250 replies posted 250 sign-ins
Hello mikes.
Assuming PSoC 5LP family discussion here...
For 5LP, I2C bootloader info is available here:
https://www.cypress.com/documentation/application-notes/an60317-psoc-3-and-psoc-5lp-i2c-bootloader
If you scroll down this page, you'll find addition documentation for bootloaders.
I know you're interested in 'host' s/w for iMXRT.  The doc's on bootloaders, contains this information.
I have no experience with iMXRT nor i2C bootloading.  Just wanted to point you towards some info to look at.
Good luck with your project.
edit: BTW, the C source code for a 5LP i2C Host is located in the zip file for AN60317.  If you're feeling ambitious, you could port this code to iMXRT.
BiBi_1928986
Level 7
Level 7
Hello mikes.
