PSoC™ 5, 3 & 1
Just wanted some info about the TIA available...as in PSOC Creator. I wanted to know the following, i'll be using a PSOC5 in a photodiode application:
Input Bias Current.
Input Voltage Noise (nV/sqrt(Hz) or any other units) as well as its noise spectrum.
Power consumption.
Masab Ahmad
ETRO_SSN583
Esteemed Contributor
The main electricals are in the datasheet for the TIA, and do not include noise
or bias current.
You might want to file a tech case here to see if you can get al least some characterization data -
www.cypress.com
“Support”
“Technical Support”
“Create a Case”
Regards, Dana.
